Geometric Network Error: Network property already exists
1911
05-13-2019 12:21 PM
WarrenDavison
We’re experiencing an error with a Geometric Network Database table. We previously opened a support ticket pertaining to this issue when this issue interrupted our Reconcile and Post process. After a support call the resolution at the time was to run the Repair Version Tables and Repair Version Metadata Tools corrected the issue. This solved the problem and proved to be a stable fix as the issue occurred a number of times over the following year. After that period the problem seemed to subside, perhaps due to decreased user activity editing the specific feature classes.
However, the problem has recently arisen again and I have more time to dedicate to troubleshooting the issue (ignorance was bliss). Previously when attempting to perform a reconcile, post, and compres of the database we would receive the following error:
"Error reconciling version SDE_USER.PWS.[
 The feature class participates in a geometric network that could not be opened.
 Network property already exists. [Property name: 'Junction Count' in the SDE_USER.N_6_Props table]]
 3 of 4 versions finished.
 WARNING 000084: Conflicts detected, aborting the reconcile.
 Reconciling version SDE_USER.FieldEdits with SDE.DEFAULT.
 Error reconciling version SDE_USER.FieldEdits.[
 4 of 4 versions finished.
 Finished reconcile.
 Succeeded at Tue Jul 18 18:27:34 2017 (Elapsed Time: 7.37 seconds)"
Today the error also appeared for users editing the data and attempting to save their edits.
Error dialog when attempting to save edits to a feature class that participates in a geometric network.
I’m hoping to get to the bottom of this and resolve the issue and restore my confidence in the integrity of our database.
A couple notes on our environment:
Oracle: v11.2.0.4.0 (11G) AIX 7.1
Geodatabase Version: 10.5.1
We also use infraMAP from iWater (uses runtime engine for 10.5.1) – this application uses geodatabase replicas that are children of a geodatabase version specific for Field Edits.
BirajaNayak
Hi Warren,
When you save edits, ArcGIS does a implicit reconcile  and you find the error which is generally you observed during reconcile process.
Have you run the "diagnose version tables" and "diagnosed version metadata". This will provide you inconsistency in your geometric network and then run corresponding repair tool to fix it.
If you are looking to get answer how these inconsistency in geometric network created, that is something difficult to answer. You many need to observed your editing workflow and introduce "diagnose version tables" and "diagnosed version metadata" steps frequently to monitor when the inconsistency started and then work on it to fix the workflow as well as data.
Hope that helps.
Biraja
WarrenDavison
Hello Biraja,
We have run the diagnose and repair tools to fix the issues, however the error tends to return and as you've mentioned it's difficult to understand where the issue is originating.
You've mentioned running the diagnose tools frequently, would you suggest possibly having these tools run on a scripted schedule so we could pinpoint when this issue occurs based on those logs from the tool?
Warren
BirajaNayak
Yes, please use python script to schedule the diagnose.
Biraja
BirajaNayak
