AnsweredAssumed Answered
Survey 123 Pull Repeat data to Report Template
Question asked by aichemist on May 9, 2019
Latest reply on Jan 31, 2020 by JTedrick-esristaff
I want to pull specific data out of the repeat option for the word template, but it looks like it pulls every row at the moment.
For example, if have 3 repeats, it will pull photo description for all 3 loop.
${#Photograph}
${photo_description}
${/Photograph}
Lets say each description has a value, and the value is test1, test2, test3
In this case, if I used the command above, I would get this as return
test1
test2
test3
What I want is to only pull the value of test 2.  I want to be able to pull specific data I wanted on a specific loop.  No calculation, just values.
What I have right now is a bunch of photo and photo description in a repeat, and I want to be able to pull the pictures 1 at a time so I can setup the word template neatly.  Does that make sense?  Not sure if this is possible with survey123 template management at the moment.
Matthew
Outcomes
