According to the docs, the visualintersect argument of the GetFeatures method Indicates whether only features that visibly intersect the geometry should be returned.
What does "visibly intersect" mean? Is there a difference between visibly intersecting something and actually intersecting something?
A visualintersect value of true means the symbol used for the feature is taken into account. So for example if you represented a city (point feature class) with a point symbol consisting of a large circle that is 100 pixels across in screen units, then if the search geometry intersects that circle (as if the circle were a polygon feature in the map), then that city feature will be returned even if the search geometry doesn't actually intersect the city's latitude and longitude point coordinates. At least that's what I have determined based on experimentation.
