NuGet restore failing for CrowdPlannerTool sample
855
05-10-2019 02:50 PM
TimWhiteaker
Occasional Contributor II
I opened the solution for the CrowdPlannerTool sample in VS 2017. As expected, VS tells me a NuGet package is missing. Step 4 of the instructions says to install the package using
Install-Package System.Windows.Controls.DataVisualization.Toolkit
When I try this, I get:
PM> Install-Package System.Windows.Controls.DataVisualization.Toolkit
Install-Package : Some NuGet packages are missing from the solution. The packages need to be restored in order to build the dependency graph. Restore the packages before
performing any operations.
At line:1 char:1
+ Install-Package System.Windows.Controls.DataVisualization.Toolkit
    + CategoryInfo          : InvalidOperation: (:) [Install-Package], InvalidOperationException
    + FullyQualifiedErrorId : NuGetMissingPackages,NuGet.PackageManagement.PowerShellCmdlets.InstallPackageCommand
Can anyone help me get this sample up and running? Thanks!
Tags (1)
by Anonymous User
Not applicable
Hello Tim, another way to reinstall an unapplied NuGet package in one of the samples within Visual Studio is to go to Tools > NuGet Package Manager > "Manage NuGet Packages for Solution..."
Then, select the NuGet package and uninstall from the project.  Afterwards, under "Browse" in the package manager UI, find the NuGet again and reinstall for the project:
Then confirm and finally, just rebuild your solution. That normally will do the trick.
TimWhiteaker
When I click Uninstall, I get an error, and it seems like the uninstall failed because the Uninstall button is still enabled.  The error says "while trying to restore package" but that message didn't appear until I clicked Uninstall.
Screenshot of failure to uninstall NuGet package
