Run Python script from button on toolbar.
2666
05-09-2019 10:13 AM
DaleShearer
Thanks for looking at my question.
    I learning Python as I go and have made some headway, so here is what I have now ran into.   I have a Python script that creates a menu, I can run it from PyScripter and it all works.
I have created a toolbar using the Python Add-In Wizard that contains a button that will be used to load/run/execute/display the menu.
What I want is to click the button, menu appears, then I work with the selections on the menu to work with the layers.
When I start ArcMap the toolbar is displayed with the button.  When I click the button I get a messagebox that I programmed in to make sure it works, one I clear the messagebox I get a quick flash on the screen that I cannot make out, and that is it.
This is the code for the button on the toolbar.
import arcpy
import pythonaddins
import os
class btnOpenMenu(object):
     def __init__(self):
            self.enabled = True
            self.checked = False
     def onClick(self):
            pythonaddins.MessageBox("Open Menu", "Layer Menu", 0)
            os.system('D:\Applications\Python\Open Menu.py')
I also tried:   os.system(r'D:\Applications\Python\Open Menu.py')   which did not work.
Thanks for your help.
DaleShearer
In the end:
execfile("D:\Applications\Python\Open_Menu.py")
is what it took to open the menu.
import arcpy
import pythonaddins
     def __init__(self):
            self.enabled = True
     def onClick(self):
            execfile('D:\Applications\Python\Open Menu.py')
DaleShearer
Well, making progress, it now works, sorta.
Changed os.system to os.startfile('D:\Applications\Python\Open_Menu.py')
Now I get the cmd window (blank) with the heading: C:Python27\ArcGIS10.5\python.exe opening.
The cmd window opens right up, then about 5-10 seconds later my menu is displayed.
So now both are open, so now I need to get the cmd window from opening.
DaleShearer
And if I close the command window the menu closes......
DaleShearer
In the end:
import arcpy
import pythonaddins
     def __init__(self):
            self.enabled = True
     def onClick(self):
