Metadata error when publishing to Data.gov
382
05-08-2019 09:46 AM
AndreaConver
New Contributor III
I am in the process of publishing a Open Data catalog to Data.gov using Esri's automatically generated /data.json file. Unfortunately, I hit a snag with this metadata validation tool: https://labs.data.gov/dashboard/validate
All of my datasets have two errors: "The property bureauCode is required" and "The property programCode is required".
I now have the codes for both of the values, but I can't figure out where to add them in AGOL. Has anyone else run into his problem? If so, how did you solve it?
AndreaConver
New Contributor III
I resolved these errors with help from Esri staff. I've copied the steps below in case someone else runs into the same issue in the future.
*Note: site must be PUBLICLY accessible to view custom config results in data.json
Step by Step Instructions
https://hub.arcgis.com/admin/sites
Click on YourSite > Groups Manager button
Example: https://hub.arcgis.com/admin/sites/56b71074912341538ae57f26e82bec2f/groups
Click the DCAT Feed button
Copy paste this code with YOUR bureau and program codes (highlighted below) anywhere after a comma and before the last bracket.
If just one bureau and program code:
"bureauCode": [
      "010:86"
    "programCode": [
        "015:001"
If more than one
"bureauCode": [
      "010:86",
      "010:04"
    "programCode": [
        "015:001",
        "015:002"
Example:
               "title": "{{default.name}}",
               "description": "{{default.description}}",
               "keyword": "{{item.tags}}",
               "issued": "{{item.created:toISO}}",
               "modified": "{{item.modified:toISO}}",
               "publisher": {
                              "source": "{{default.source.source}}"
"bureauCode": [
      "010:86"
    "programCode": [
        "015:001"
               "contactPoint": {
                              "fn": "{{item.owner}}",
                              "hasEmail": "{{org.portalProperties.links.contactUs.url}}"
