AnsweredAssumed Answered
ArcGIS Server 10.6.1 - logging javaw causes high cpu
Question asked by fsheagle-co-nz-esridist Employee on May 7, 2019
Latest reply on May 26, 2020 by AngusHooper
Hi there,
has anyone seen the logging process for ArcGIS Server spike CPU usage?
When Esri replaced geronimo  at 10.6 I'm assuming that the remaining javaw process is still the logging manager - the command line for 10.6.1 and 10.5.1 are almost the same.
We are currently performing some load testing and have the GIS server logs set to FINE - so we can analyse the logs with tools like System Log Parser afterwards.
We have Load Runner scripts to test with up to 200 users and during the test period we are seeing the javaw process spike to almost 70% CPU alone which affects the rest of the machine. I'm assuming that with the additional load and amount of incoming requests this process is struggling to keep up? This in turn starts to affect the performance of the server which affects the test which affects the results etc.
Has anyone seen this process do this? I have seen it use a load of memory but not spike the CPU.
Fraser
process that spikes out
This one
Jonathan Quinn
Derek Law
Outcomes
