How to load in-memory layer into ArcMap?
705
05-07-2019 09:11 AM
NealBanerjee
I have some ModelBuilder models and Python scripts that create "in-memory" feature layers.  If they are already created, is there a way to load them into ArcMap?  If I try to run a standard geoprocessing tool in my session, I can they show up as options, but wanted to see if direct way I can load them.
Neal
Tags (1)
DuncanHornby
MVP Notable Contributor
You are asking one question for two very different environments so its not clear what you are really asking.
If you are in modelbuilder and a tool creates an in_memory featureclass then if you feed that into a Make FeatureLayer tool and set the output to Add to Display that would normally add it the table of contents in your map document.
