LicenseInitilizer memory leak on db connection?
238
05-05-2019 07:08 PM
by Anonymous User
Not applicable
LicenseInitializer leaks memory when call are made to a SQL server using LINQ.
The code below leaks finalization handles, one for each data context created.  I believe that the esri licence system is listening for database connection events and firing an event handler.  I expect this is required to check licencing of SDE databases. The SQl server I am using does not have an SDE, it is a vanilla MS SQL server,  Evidently the fired event handler creates a number of objects that are not finalized/disposed correctly and accumulate in memory as they can't be garbage collected.
Adding a "GC.WaitForPendingFinalizers();" in the for loop, after the DataContext has been destroyed seems to release the offending objects but this is computationally expensive.
I believe this is a bug in esri's licencing system.  Has anyone seen this previously.
Steven
using ESRI.ArcGIS.esriSystem;
using System;
using System.Collections.Generic;
using System.Text;
using System.Data.Linq;
namespace ArcLeakTesting
    class Program
        private static LicenseInitializer m_AOLicenseInitializer = new ArcLeakTesting.LicenseInitializer();
        [STAThread()]
        static void Main(string[] args)
            m_AOLicenseInitializer.InitializeApplication(new esriLicenseProductCode[] {esriLicenseProductCode.esriLicenseProductCodeStandard , new esriLicenseExtensionCode[] { });
            for (int i = 0; i < 1000000; i++)
                using (DataContext db = new DataContext(@"Server=tcp:XXXX\SQLEXPRESS,YYYYY;Database=ZZZZZ;User Id = AAAAAA;Password=BBBBBBB"))
            m_AOLicenseInitializer.ShutdownApplication();
