Create Arc/Circle by Edge
460
05-03-2019 09:06 AM
CarlosLeon
I'm using an image map to create a "quick" shapefile of a local airport.  Just the runway, taxiways and most paved areas.  I'm wanting to use the fillet tool to connect the polylines, but I do not know the radius of curves.  How can I measure this or how can I temp place an arc/circle by edge to then measure the radius?
CarlosLeon
To the many replies (/sarcasm), I figured this out on my own.  Turns out the Fillet Tool was useful in itself.  The tool inserts a tangent curve fillet dynamically.  Since I was using a LARIAC image of the airport, I could simply place the correct radius curve visually.  I didn't need to know the curve radius to do what I needed to do as this shape file was to be a simplified visual portrayal of the airport surfaces and not an exacting construction plan.
However, I still have not found a manner in which to place a circle by edge in ArcMap.
