Looping error - Bug?
418
04-29-2019 06:21 AM
PanGIS
Occasional Contributor III
Hi guys,
I was creating a feature class by importing fields from another layer.
I was in editing and I forgot to save. I was not working on the layer I used to import though. Anyway, I got this error.
The problem now is that I cannot close this error and save the edits as this message keeps on reopening in a loop.
Happened again once, I solved by closing the project.
Can it be a bug? (ArcGIS PRO 2.2.4)
Thanks.
Tags (3)
JoeBorgione
Which feature class were you editing?  The one you are using as the template?  Are all the feature classes in the same fgdb?
PanGIS
No, and this is the strange:
1. I was editing FC 1 in GDB1
2. I created FC 2 in GDB2 importing fields from FC 3 in GDB2.
Here I got that error.
JoeBorgione
That is pretty weird...  I was hoping it was something simple like everything was in the same gdb etc....
