AnsweredAssumed Answered
Domains assigned to field 'AssetType' must not be shared error
Question asked by anthony.ryan_ergon on Apr 24, 2019
Latest reply on Apr 24, 2019 by PLeBlanc-esristaff
Hi there,
I have created an asset package using the 'Create a utility network' gp tool and added to domain networks (eg Electrical & Communication) within an enterprise geodatabase. This was exported using the 'Export Asset Package' un gp tool.
A few small modification were made to the exported asset package (file geodatabase) by adding 3 coded domains & 3 subtypes to StructureJunction feature class. The 3 coded domains were then associated to their respective subtype.
Another eneterprise geodatabase was setup and I started the steps to apply this asset package
'Stage the Utility Network' was successful but 'Apply Asset Package' generated the error below.
Start Time: Wednesday, 24 April 2019 5:18:11 PM
Running script AssetPackageToUtilityNetwork...
ArcGIS Pro 2.3.2.15850
untools 2.3.2
Parallel processing enabled: 6
The asset package has the following errors:
Item Field OID Value Message Level
0 None None None StructureJunction/Pole | StructureLine/Pole Domains assigned to field 'AssetType' must not be shared error
1 None None None StructureJunction/Pillar | StructureLine/Pillar Domains assigned to field 'AssetType' must not be shared error
2 None None None StructureJunction/Guy | StructureLine/Guy Domains assigned to field 'AssetType' must not be shared error
Failed to execute (AssetPackageToUtilityNetwork).
Failed at Wednesday, 24 April 2019 5:18:34 PM (Elapsed Time: 22.81 seconds)
Has anybody come across this error before?
Outcomes
