Update survey form from Survey123 Connect --> Save data
782
04-24-2019 06:29 AM
ArnaudDemontis
Dear Survey123 community, I need help to update my Survey form from Survey123 Connect to ArcGis Online.
When I want to publish the new form, I have a warning : all data could be lost.
So, I would like to save data. I know I can export it in Geodatabase (FGDB). But, next step, if all data are lost, how can I put this FGDB in my new survey layer? Or how can I put the features from my FGDB into my new survey layer?
Many thanks for your help,
Arnaud
DougBrowning
MVP Esteemed Contributor
In ArcPro just use an Append like any other transfer from Feature Class to Feature Class.  The thing here is preserving GlobalIDs.  There is a setting for that now I Pro I read.
ArcMap is tougher since you have to check out a copy, append, then check back in.
ArnaudDemontis
Thank you for your answer @Doug, this is ok for the layer. It's not ok for the related tables... Because my Survey contain Repeats (Begin repeat / end repeat) that generate related tables.
DougBrowning
This will work on Related tables just fine.  Just append in like the layer.
