Why won't ArcGIS Pro symbolize a total range?
631
04-22-2019 10:52 AM
EricEagle
Occasional Contributor III
I have a hex grid (polygons) containing a Point_Count field (an output of Summarize Within).
The FC contains around 163,000 rows.
The Point_Count field contains values between 1 and 1200.
However, whenever I try to do a graduated symbology, the Maximum is set to 661.  When I look at statistics on the Symbology panel, it incorrectly lists the Maximum as 661.  Thus, even if I manually set the histogram to 1200 max, it "snaps" back to 661 regardless.  Consequently it will not symbolize around 200 polygons that represent values over 661.
I tested this error by doing the following:
- Creating a new feature class containing the same content and loading it from scratch (the previous layer was loaded and symbolized via script).  No difference.
- Took the same data (both original and copied) and loaded it into QGIS 3.4.  It picked up the correct min/max values without issue on both datasets.
My guess is that Pro is trying to be "helpful" somewhere but durned if I know how or why.
Crossposted from https://gis.stackexchange.com/questions/319517/why-is-arcgis-pro-not-symbolizing-my-entire-range-of-...
Note: no specific data is required to recreate this - anyone can take a random cluster of dots across a grid of this size, run summarize within, and obtain a similar output.  My cells are 50m radius (circle inside).
Tags (1)
KoryKramer
Esri Community Moderator
Have you tried upping the Maximum sample size?
KoryKramer
EricEagle
Hey Kory, that did the trick.  Because of the distribution I had to push it up to 163000 but it did work.  Thanks!
KoryKramer
Great.  You might want to go over here and vote up if you haven't: https://community.esri.com/ideas/14414-no-sample-sized-reached-error-in-arcgis-pro
