Publishing multiple surveys to different layers and tables in the same service
369
04-19-2019 08:15 AM
JosephGrossman
New Contributor III
James Tedrick‌ I am trying to publish multiple surveys to different layers and tables in the same feature service. I am using a custom URL to pass the guid to the survey and have a relationship layer in the gdb to allow the collector layer to be related to the survey 123 endpoint data. The data has related tables and layers. I have 7 surveys I want to publish to 7 different layers. Two of them have repeating tables.
I was able to publish the  feature service and the surveys to the feature service, but when I try to submit them the surveys get stuck on "getting service information." Do you have any advice?
Thanks!
Joe
JosephGrossman
New Contributor III
I have resolved some of this issue.
DougBrowning
MVP Esteemed Contributor
What helped?  I am having this same issue right now.  It seems from the log that it is mad there are other relationship classes besides the ones between the forms.  (I have a few extra relationships classes that point from the Form to a Master set).
