Year only in a date field
7917
16
04-17-2019 10:57 AM
JoeBorgione
I have a feature class with a numeric field representing a year in the form of yyyy (2017).  ArcGIS Pro has a tool called Convert Time Field that can take an integer and write it to an existing date field or it will add one for you.
When I run the tool it returns a date in the form of 1/1/2017.  Is there a way to format a date field to show just the year?
Egge-Jan_Pollé
MVP Regular Contributor
Hi Joe Borgione‌,
The answer to your question is, I think: No. No, not in ArcGIS Pro.
The display format for dates depends on your regional settings. ArcGIS Pro follows the Windows settings for date formats and uses the system short date format (numerical) to display dates, independent of the underlying database's format on the system.
Of course if you display your data somewhere else, e.g. in ArcGIS Online, you can choose to format your dates to only show the year.
But then I have this question: why would you convert your year values to dates to begin with? If the year really is the only thing you are interested in - and there really is no day, no month, no time to store - then maybe the numeric field you started out with would be sufficient, or not?
What do you think?
Best regards,
Egge-Jan
JoeBorgione
why would you convert your year values to dates to begin with? It was requested of me.....
Looking at this now:  https://community.esri.com/thread/222378-text-to-date-using-arcade-expressions, it's just that we have a 'year' field that was provided as an int....
by Anonymous User
Not applicable
Hi Egge-Jan,
I'm curious if one application that a user would want to use the year as a date field instead of a numeric field would be for space-time binning(?).  Say one wanted to evaluate the spatial distribution of model polygons on a landscape over many years, but the year field is numeric, would this be an instance where the user would want to convert year values to dates? And if so, is there a workflow you are familiar with to achieve that result?
Zachary
DanPatterson_Retired
JoeBorgione
hahahaha; my stupid question of the day left you speechless!
Dan Patterson
now remember Arcade is an evolving language... I am sure it is just moi and not something that they didn't test on a date field
Xander Bakker‌ can you spot my error?
JoeBorgione
I'm thinking this a red herring:  one of the guys here wants to use the integer field as a year in a dashboard.  Not exactly sure what the objective is.  On to other more intangible things....
XanderBakker
Esri Esteemed Contributor
Not sure what the error is, but if you want to strore the year in a separate field, you would create an integer field, and doing a calculation with Arcade on a date field using Year($feature.NameOfDateField) and storing the result in an integer field will just store the year value. Just tried it and it works as it is supposed to. Not sure what might be different in your case.
Funky in the field calculator using arcade on a date field
2019-04-17 8:11:55 AM
using
Year($feature.DT_test)
yields
1905-07-11
So I would say no as well, but I am sure it is something silly or just something
