AnsweredAssumed Answered
Clarification on mobileLayout
Question asked by franklin.alexander on Apr 16, 2019
Latest reply on Apr 16, 2019 by franklin.alexander
I know I have asked a similar question, and have read numerous posts on this subject, but I am still confused about how the mobileLayout section in the main app config is supposed to work. To my understanding, any widget or map configurations in the mobileLayout section should kick in when the app is run in mobile. I have viewed the Config Manager and jimu utilities where this behavior appears to be defined, but when I try and make a change in a configuration in the mobileLayout section, it always appears to be ignored. I usually end up giving up and modifying the javascript in some file to force the desired behavior. In this case I do not want the legend to openAtStart in mobile config, but just setting this to false in the mobileLayout does not work (it still opens). I would also like to set a new map extent in mobile, but no luck there either. It would be really nice if I could get this to work since I run in to this a lot and it would save a lot of time. Here is my entire main config:
  "theme": {
    "name": "FWRITheme",
    "styles": [
      "green",
      "default",
      "yellow",
      "black",
      "blue"
    "version": "2.10",
    "sharedTheme": {
      "isPortalSupport": true,
      "useHeader": false,
      "useLogo": false
  "portalUrl": "https://myfwc.maps.arcgis.com",
  "appId": "",
  "authorizedCrossOriginDomains": [],
  "title": "FWC Fish Stocking Locator",
  "subtitle": "Fish and Wildlife Conservation Commission",
  "keepAppState": false,
  "logo": "images/logo.png",
  "geometryService": "https://utility.arcgisonline.com/arcgis/rest/services/Geometry/GeometryServer",
  "links": [],
  "widgetOnScreen": {
    "widgets": [
        "uri": "themes/FWRITheme/widgets/HeaderController/Widget",
        "position": {
          "left": 0,
          "top": 0,
          "right": 0,
          "height": 40,
          "relativeTo": "browser"
        "version": "2.10",
        "id": "themes_FWRITheme_widgets_HeaderController_Widget_20",
        "name": "HeaderController"
        "uri": "widgets/Scalebar/Widget",
        "position": {
          "left": 7,
          "bottom": 25,
          "relativeTo": "map"
        "version": "2.10",
        "id": "widgets_Scalebar_Widget_21",
        "name": "Scalebar"
        "uri": "widgets/Search/Widget",
        "position": {
          "left": 55,
          "top": 5,
          "relativeTo": "map"
        "version": "2.10",
        "id": "widgets_Search_Widget_22",
        "name": "Search"
        "uri": "widgets/Coordinate/Widget",
        "position": {
          "left": 7,
          "bottom": 5,
          "relativeTo": "map"
        "version": "2.10",
        "id": "widgets_Coordinate_Widget_23",
        "name": "Coordinate"
        "position": {
          "left": 55,
          "top": 45,
          "relativeTo": "map"
        "placeholderIndex": 1,
        "id": "_27",
        "name": "SearchStockedFish",
        "label": "Search Stocked Fish",
        "version": "2.10",
        "closeable": true,
        "uri": "widgets/SearchStockedFish/Widget",
        "config": "configs/SearchStockedFish/config__27.json",
        "openAtStart": true
        "position": {
          "left": 105,
          "top": 45,
          "relativeTo": "map"
        "id": "_28",
        "name": "WaterbodySearch",
        "label": "Search for Waterbodies",
        "version": "2.9",
        "closeable": true,
        "uri": "widgets/WaterbodySearch/Widget",
        "config": "configs/WaterbodySearch/config__28.json",
        "icon": "configs\\WaterbodySearch\\icon__28.png"
        "position": {
          "left": 155,
          "top": 45,
          "relativeTo": "map"
        "id": "_26",
        "name": "Identify",
        "version": "2.9.0.1",
        "uri": "widgets/Identify/Widget",
        "closeable": true,
        "IsController": false,
        "config": "configs/Identify/config__26.json"
        "position": {
          "left": 205,
          "top": 45,
          "relativeTo": "map"
        "id": "_24",
        "name": "Print",
        "version": "2.10",
        "closeable": true,
        "uri": "widgets/Print/Widget",
        "config": "configs/Print/config__24.json"
        "position": {
          "left": 255,
          "top": 45,
          "relativeTo": "map"
        "id": "_25",
        "version": "2.5",
        "closeable": true,
        "uri": "widgets/eBookmark/Widget",
        "name": "eBookmark",
        "config": "configs/eBookmark/config__25.json"
        "uri": "widgets/OverviewMap/Widget",
        "position": {
          "right": 0,
          "bottom": 0,
          "zIndex": 1,
          "relativeTo": "map"
        "version": "2.10",
        "id": "widgets_OverviewMap_Widget_29",
        "name": "OverviewMap"
        "uri": "widgets/HomeButton/Widget",
        "position": {
          "left": 7,
          "top": 75,
          "relativeTo": "map"
        "version": "2.10",
        "id": "widgets_HomeButton_Widget_30",
        "name": "HomeButton"
        "uri": "widgets/MyLocation/Widget",
        "position": {
          "left": 7,
          "top": 150,
          "relativeTo": "map"
        "version": "2.10",
        "visible": false,
        "id": "widgets_MyLocation_Widget_31",
        "name": "MyLocation"
        "uri": "widgets/AttributeTable/Widget",
        "visible": false,
        "version": "2.10",
        "position": {
        "id": "widgets_AttributeTable_Widget_32",
        "name": "AttributeTable"
        "uri": "widgets/Splash/Widget",
        "visible": false,
        "position": {
        "version": "2.10",
        "id": "widgets_Splash_Widget_33",
        "name": "Splash"
        "uri": "widgets/ZoomSlider/Widget",
        "position": {
          "top": 5,
          "left": 7,
          "relativeTo": "map"
        "version": "2.10",
        "id": "widgets_ZoomSlider_Widget_34",
        "name": "ZoomSlider"
        "uri": "widgets/ExtentNavigate/Widget",
        "visible": false,
        "position": {
          "top": 190,
          "left": 7,
          "relativeTo": "map"
        "version": "2.10",
        "id": "widgets_ExtentNavigate_Widget_35",
        "name": "ExtentNavigate"
        "uri": "widgets/FullScreen/Widget",
        "visible": true,
        "position": {
          "top": 110,
          "left": 7,
          "relativeTo": "map"
        "version": "2.10",
        "id": "widgets_FullScreen_Widget_36",
        "name": "FullScreen"
        "uri": "widgets/FWRISplash/Widget",
        "positionRelativeTo": "browser",
        "id": "widgets_FWRISplash_Widget_37",
        "name": "FWRISplash",
        "version": "0.0.1",
        "position": {
        "config": "configs/FWRISplash/config__38.json"
        "uri": "widgets/FWRIViewSettings/Widget",
        "id": "widgets_FWRIViewSettings_Widget_38",
        "name": "FWRIViewSettings",
        "version": "0.0.1",
        "position": {
        "uri": "widgets/LocalLayer/Widget",
        "id": "widgets_LocalLayer_Widget_39",
        "name": "LocalLayer",
        "version": "2.0",
        "position": {
        "config": "configs/LocalLayer/config_widgets_LocalLayer_Widget_39.json"
    "panel": {
      "uri": "jimu/OnScreenWidgetPanel",
      "position": {
        "relativeTo": "map"
  "map": {
    "3D": false,
    "2D": true,
    "position": {
      "left": 0,
      "top": 40,
      "right": 0,
      "bottom": 0
    "itemId": "3dbbb8f6d83c481381decdb150963858",
    "mapOptions": {
      "extent": {                       //I want to change this extent in mobile
        "xmin": -10223667.439313974,
        "ymin": 2732381.698461617,
        "xmax": -8364718.911418981,
        "ymax": 3745019.449183363,
        "spatialReference": {
          "wkid": 102100
    "id": "map",
    "mapRefreshInterval": {
      "useWebMapRefreshInterval": true
  "widgetPool": {
    "panel": {
      "uri": "themes/FWRITheme/panels/FoldablePanel/Panel",
      "position": {
        "top": 5,
        "right": 5,
        "bottom": 5,
        "zIndex": 5,
        "relativeTo": "map"
    "widgets": [
        "uri": "widgets/Legend/Widget",
        "visible": true,
        "version": "2.10",
        "id": "widgets_Legend_Widget_18",
        "name": "Legend",
        "openAtStart": true,  // I do not want this to open at start in mobile
        "index": 2
        "uri": "widgets/LayerList/Widget",
        "version": "2.10",
        "id": "widgets_LayerList_Widget_19",
        "name": "LayerList",
        "index": 3,
        "config": "configs/LayerList/config_widgets_LayerList_Widget_19.json",
        "openAtStart": false
        "name": "eDraw",
        "label": "Draw and Measure",
        "version": "2.8.1",
        "visible": false,
        "uri": "widgets/eDraw/Widget",
        "config": "configs/eDraw/config_widgets_eDraw_Widget_40.json",
        "index": 5,
        "id": "widgets_eDraw_Widget_40"
        "name": "HelpfulLinks",
        "version": "2.10",
        "uri": "widgets/HelpfulLinks/Widget",
        "config": "configs/HelpfulLinks/config_widgets_Links_Widget_41.json",
        "index": 6,
        "id": "widgets_HelpfulLinks_Widget_41"
    "groups": []
  "mobileLayout": {
    "widgetOnScreen": {
      "widgets": [
          "position": {
            "left": 0,
            "top": 0,
            "right": 0,
            "height": 40,
          "version": "2.10"
          "position": {
            "left": 7,
            "bottom": 40,
            "relativeTo": "map"
          "version": "2.10"
          "position": {
            "left": 55,
            "top": 5
          "version": "2.10"
          "position": {
            "left": 7,
            "bottom": 17,
            "relativeTo": "map"
          "version": "2.10"
          "position": {
            "left": 55,
            "top": 45
          "position": {
            "left": 105,
            "top": 45
          "position": {
            "left": 155,
            "top": 45
          "position": {
            "left": 205,
            "top": 45
          "position": {
            "left": 255,
            "top": 45
          "position": {
            "right": 0,
            "bottom": 0,
            "zIndex": 1
          "version": "2.10"
          "inPanel": false,
          "position": {
            "left": 7,
            "top": 75
          "version": "2.10"
          "inPanel": false,
          "position": {
            "left": 7,
            "top": 110
          "version": "2.10"
          "version": "2.10",
          "visible": false,
          "position": {
          "visible": false,
          "position": {
          "version": "2.10"
          "visible": true,
          "position": {
            "top": 5,
            "left": 7
          "version": "2.10"
          "visible": false,
          "position": {
            "top": 190,
            "left": 7
          "version": "2.10"
          "visible": false,
          "position": {
            "top": 150,
            "left": 7
          "version": "2.10"
    "map": {
      "position": {
        "left": 0,
        "top": 40,
        "right": 0,
        "bottom": 0
      "mapOptions": {
        "extent": {
          "xmin": -97,  // change does not take effect
          "ymin": 27,
          "xmax": -88,
          "ymax": 36,
            "wkid": 102100
    "widgetPool": {
      "panel": {
        "position": {
          "top": 5,
          "right": 5,
          "bottom": 5,
          "zIndex": 5
      "widgets": [
          "visible": false,
          "version": "2.10",
          "name": "Legend",
          "openAtStart": false,  // opens anyway
          "index": 1
  "loadingPage": {
    "backgroundColor": "#508dca",
    "backgroundImage": {
      "visible": false
    "loadingGif": {
      "visible": true,
      "uri": "configs/loading/images/predefined_loading_1.gif",
      "width": 58,
      "height": 29
  "wabVersion": "2.10",
  "isTemplateApp": true,
  "isWebTier": false,
  "httpProxy": {
    "useProxy": true,
    "alwaysUseProxy": false,
    "url": "",
    "rules": []
  "dataSource": {
    "dataSources": {
      "widget~_27~0": {
        "id": "widget~_27~0",
        "type": "Features",
        "label": "Find Stocked Fish",
        "dataSchema": {
          "geometryType": "esriGeometryPoint",
          "fields": [
              "name": "OBJECTID",
              "type": "esriFieldTypeOID",
              "alias": "OBJECTID",
              "domain": null
              "name": "Shape",
              "type": "esriFieldTypeGeometry",
              "alias": "Shape",
              "domain": null
              "name": "COUNTY",
              "type": "esriFieldTypeString",
              "alias": "COUNTY",
              "length": 254,
              "domain": null
              "name": "WATERBODY",
              "alias": "WATERBODY",
              "length": 254,
              "domain": null
              "name": "FISH_STOCK",
              "type": "esriFieldTypeDouble",
              "alias": "FISH_STOCK",
              "domain": null
              "name": "SPECIES",
              "alias": "SPECIES",
              "length": 254,
              "domain": null
              "name": "SIZE",
              "alias": "SIZE",
              "length": 254,
              "domain": null
              "name": "PHASE",
              "alias": "PHASE",
              "length": 254,
              "domain": null
              "name": "LONG",
              "alias": "LONG",
              "domain": null
              "name": "LAT",
              "alias": "LAT",
              "domain": null
              "name": "Year",
              "alias": "Year",
              "length": 10,
              "domain": null
              "name": "created_user",
              "alias": "created_user",
              "length": 255,
              "domain": null
              "name": "created_date",
              "type": "esriFieldTypeDate",
              "alias": "created_date",
              "length": 8,
              "domain": null
              "name": "last_edited_user",
              "alias": "last_edited_user",
              "length": 255,
              "domain": null
              "name": "last_edited_date",
              "alias": "last_edited_date",
              "length": 8,
              "domain": null
          "displayField": "COUNTY",
          "objectIdField": {
            "name": "OBJECTID",
            "domain": null
          "typeIdField": null
      "widget~_27~1": {
        "id": "widget~_27~1",
        "type": "Features",
        "label": "Find a Waterbody",
        "dataSchema": {
          "fields": [
              "name": "OBJECTID",
              "domain": null
              "name": "FEATURE_ID",
              "alias": "GNIS ID",
              "domain": null
              "name": "FEATURE_NA",
              "alias": "Name",
              "length": 254,
              "domain": null
              "name": "COUNTY_NUM",
              "alias": "County FIPS Code",
              "domain": null
              "name": "PRIMARY_LA",
              "alias": "Latitude (DMS)",
              "length": 254,
              "domain": null
              "name": "SOURCE_LAT",
              "alias": "Source Latitude (DMS)",
              "length": 254,
              "domain": null
              "name": "SOURCE_LON",
              "alias": "Source Longitude (DMS)",
              "length": 254,
              "domain": null
              "name": "SOURCE_L_1",
              "alias": "Source Latitude",
              "domain": null
              "name": "SOURCE_L_2",
              "alias": "Source Longitude",
              "domain": null
              "name": "MAP_NAME",
              "alias": "USGS Quad Name",
              "length": 254,
              "domain": null
              "name": "Shape",
              "alias": "Shape",
              "domain": null
              "name": "FEATURE_CL",
              "alias": "FEATURE_CL",
              "length": 254,
              "domain": null
              "name": "STATE_ALPH",
              "alias": "STATE_ALPH",
              "length": 254,
              "domain": null
              "name": "STATE_NUME",
              "alias": "STATE_NUME",
              "domain": null
              "name": "COUNTY_NAM",
              "alias": "COUNTY_NAM",
              "length": 254,
              "domain": null
              "name": "PRIM_LONG_",
              "alias": "PRIM_LONG_",
              "length": 254,
              "domain": null
              "name": "PRIM_LAT_D",
              "alias": "PRIM_LAT_D",
              "domain": null
              "name": "PRIM_LONG1",
              "alias": "PRIM_LONG1",
              "domain": null
              "name": "ELEV_IN_M",
              "alias": "ELEV_IN_M",
              "domain": null
              "name": "ELEV_IN_FT",
              "alias": "ELEV_IN_FT",
              "domain": null
              "name": "DATE_CREAT",
              "alias": "DATE_CREAT",
              "length": 8,
              "domain": null
              "name": "DATE_EDITE",
              "alias": "DATE_EDITE",
              "length": 254,
              "domain": null
              "length": 255,
              "domain": null
              "length": 8,
              "domain": null
              "length": 255,
              "domain": null
              "length": 8,
              "domain": null
          "displayField": "MAP_NAME",
          "objectIdField": {
            "name": "OBJECTID",
            "domain": null
          "typeIdField": null
    "settings": {}
  "logoLink": "http://"
 Thanks!!
Outcomes
