Maplex Engine doesnt show up when exported map to pdf
1023
04-08-2019 11:53 PM
RudiniRudini
Hi all
im using maplex engine for my labeling feature, when i see in the layout view i can see the label workd
but when i export it to the pdf my label doesnt show up..
its only show my feature
does anyone know how to fix this problem?
thanks
ImranKhan_P
New Contributor III
Hello Rudini Rudini
What version of ArcMap are you using?
I have followed the same workflow as you have mentioned and I am able to export the PDF without loosing any labeling.
Is it possible for you to provide the Map Package so that I can check the issue?
RudiniRudini
Hi Imran Khan Pattan‌ thanks for answer my question.
im using arcgis ver 10.6
the map package will sent to your PM..
thanks
ImranKhan_P
New Contributor III
Hi Rudini Rudini
I have gone through your Map Package. But, No Labeling has been done in the map. I would really appreciate it if you could enable labeling and send it again so that I can export it as a PDF right away.
RudiniRudini
sent it to your email Mr Pattan..
thanks again for helping
