Survey 123 Connect
343
04-08-2019 07:37 AM
by Anonymous User
Not applicable
Is anyone else having issues with 123 connect? I have multiple surveys in my connect folder but when I try to select a survey to edit it opens up a different survey. Example. I have survey A, B, C, and D. When I try to select B, C, or D, it opens up survey A every time. I deleted and re-downloaded 123 Connect and the problem still exists.
Austin
by Anonymous User
Not applicable
Hi Austin,
Are you still having this issue? What version of Connect are you using and on what OS version?
How did you create the surveys, from new advanced template, or from existing survey or feature service?
What does the My Survey Designs folder look like in C:\Users\{username}\ArcGIS\My Survey Designs\. Do you have many folders of the same survey in here?
Phil.
by Anonymous User
Not applicable
The issue seems to be resolved. I opened it up this morning to edit some surveys and all seems to be working correctly now. Thank you for the help.
Austin Wittrock
Kentucky Department of Fish and Wildlife Resources
Daniel Boone NF, Cumberland District
2375 Kentucky 801 S
Morehead KY 40351
(513)-405-6294 -Cell
(606)-780-0854 -Office
