Address Locators in a gedodatabase 10.6.1 issue
958
6
04-05-2019 12:18 PM
TimWitt2
Hey everybody,
I just migrated from 10.3.1 to 10.6.1 and now when I open one of the geodatabases that has my address locators in it, I don't see them anymore. Is this a know issue?
To update one of my other programs that uses those address locators,I need to be able to rebuild those locators (they are 10.1 locators).
Any input is appreciated!
Tim
MichaelVolz
Esteemed Contributor
MichaelVolz
JoeBorgione
Tim- I think after about 10.3.1 ESRI forces your hand not to store locators as a geodatabase object.  At one time I did the same thing, so my locators, in data, match to data, and out data, were all in the same container.  It seems to me I went away from that practice before 10.x, as it was not considered best practice.  From the help docs :
Locators should be stored in a file folder so you take advantage of new features that are not supported for locators stored in geodatabases, such as performance improvements, multithreading capabilities, and suggestions support. ArcGIS 10.4 is the last release to support storing locators in geodatabases.
TimWitt2
I would totally do that, if it wasnt for our 911 mapping software to require it being in a gdb
MichaelVolz
Sounds like a show-stopper until you can upgrade your 911 mapping software that does not require address locators stored in a gdb.
JoeBorgione
Always a problem with 3rd party apps.  When I was dispatching I had the same sorts of issues.  Are you going back to the earlier version?
Tim Witt
TimWitt2
I might set up a 2nd PC with 10.3.1 just to create my updates.
