Survey123 Webapp does not allow Portal access.
505
04-04-2019 11:47 AM
TKSHEP
New Contributor III
Does anyone know of a workaround to this bug for Survey123?
The status of Esri BUG-000120809 - Survey123 for ArcGIS web app does not allow Portal for ArcGIS users accessing a survey link to be prompted for sign in when Portal for ArcGIS is configured with Integrated Windows Authentication (IWA). - that you have been associated with has been changed to Not in Current Product Plan.
Public Explanation: Currently, when attempting to access a survey that has been shared from an IWA Portal using a share url in the following format...https://survey123.arcgis.com/share/<itemid>?portalUrl=<portal>/portal the submitter is directed to a page stating "The survey does not exist or is not accessible."
In the top right corner, there is an option to 'Sign In'.
After selecting this, the submitter is redirected to a Sign In dialogue to authenticate with their IWA credentials.  After doing so, the survey can be accessed successfully.
Thank you!
JamesTedrick
Esri Esteemed Contributor
Hi Trisha,
Just to check, you are using a form that was published by Survey123 3.2 or later? This should have been addressed in that release.
TKSHEP
New Contributor III
Yes, they have all been published with version 3.3.51.
Thank you!
