HI, robert
i have concern in measure widget,i want to change units of area,after the area calculation are added to map as graphic
for example i have measured area with miles,added it lable's to map, if i change the unit as kilometes from drop-down,the graphic on the map should be changed to kilometes.
https://community.esri.com/docs/DOC-3209-measure-widget-21-for-web-app-builder
im using above measure widget
Currently, the graphic would have to be removed and re-added. The label will not update with a unit change.
