ArcGIS Pro Field Calculator
4602
04-02-2019 12:46 PM
EricEscobar
I am new to the ArcGIS Pro and I am having trouble calculating a simple text string in my attribute table using the field calculator.  What I am trying to accomplish is to populate a field with the text "LED".
Anyone have any insight on how to accomplish this in Pro?
Tags (1)
DylanHarwell
First, ensure the field you are trying to populate is a text field. If it is a number, date, or any other type this would cause it to fail. Click the field heading in the attribute table, click 'Calculate'. In the Calculate Field pane, type "LED" in the entry box below where it says "FIELD NAME" = , then click Run
DylanHarwell
EricEscobar
Thank you, Dylan!  That did the trick.  I was using exclamation points instead of quotes.
DylanHarwell
Ah, yes, quotes for strings. Exclamation marks are used around a field name, like if you were calculating field values from one field to another, then your calculate field pane expression would look like this:  "FIElD1" = !Field2!
EricEscobar
Makes total sense.  Yeah, I was under the impression that it had to be under exclamation marks.  Thanks once again.
