AnsweredAssumed Answered
Survey 123 "Select One" Capacity
Question asked by jmriggsbee on Apr 2, 2019
Latest reply on Apr 4, 2019 by JTedrick-esristaff
I am trying to create a form, which has all our address points for the county as a Select One autocomplete. When I try and upload the survey to AGOL, I get an error code 400 on the service definition section of the upload. I have deleted the folder and feature service from AGOL, and the local .iteminfo file to reattempt upload. I checked for duplicates within the data set, and removed them. When I refresh the excel file S123 Connect takes about 10 minutes to load the survey. The survey consist of 3 questions: address, condition, comments. There are approximately 72,000 address points that I am trying to add to the Select One field. Is quantity of selection points hindering my upload?
Update: When trying to publish from Connect, under options, toggling off "Create coded value domains from choices" allowed me to upload the survey. However, the coded values was the key I was going to use to map once they are done using the survey.
The form is downloadable to iOS S123 app, but will not open, nor will it open in the browser. However, on the desktop, the survey will open within the browser. Data tab errors out when accessing through S123 website.
Outcomes
