How to enable editing options for a feature layer published through Arcmap in Portal?
421
03-31-2019 11:12 PM
AbdulWahid_GIS_Expert
       I am trying to enable editing for a feature layer I published through ArcMap but when I look at the edit page in Portal contents, there is no option to enable editing (or sync, export data, etc). If I load the data directly from my computer as a zipped shapefile then I am able to view the enable editing options and then edit the layer within the map without any problems.
I already configured my hosted layer (from a published service through Arcmap) to allow edits and syncs. What settings do I need to change to gain access to Portal's 'enable editing' options?
I am using ArcMap 10.6.1 and Portal 10.6.1 My arcgis server is federated.
Any help will be appreciated.
EricPeña
I am having the same issue.  Feature layer edit settings have disappeared in the Portal item Settings tab.  I've tried overwriting and republishing with full feature editing enabled from ArcGIS Pro with no luck.
