Is there a way to change a features attribute based on coincident surface geometry? I'm trying to figure out how I could arrange this; it would definitely be more efficient compared to scanning around and changing them manually.
Essentially my map has surfaces that have a road running through them. I'm hoping to configure it in such a way that all roads that run through one of the surfaces will be marked as a through route and the remaining roads will be unchanged.
Any help is appreciated.
Thanks.
You might have a look at some of the Spatial Join and Spatial Adjustment tools...
