ArcGIS Maps for SharePoint configuration poroblem.
1507
6
03-28-2019 03:24 AM
JustynaKobyka
Hi. When I try to configure The ArcGIS Maps for SharePoint, i can't finde he ArcGIS Maps for SharePoint Configuration page. When I click on ArcGIS in my site contents: it opens a browse with information abaut this add, any link or option to configure it. I use Online SharePoint and I'm the global administrator. I try to do this tutorial: http://doc.arcgis.com/en/maps-for-sharepoint/office-365/install-and-configure/configure-maps-for-sha..., but i cant finde option from:
,,Access ArcGIS Maps for SharePoint app configuration" part.
RudyRuvalcaba1
Hi Justyna Kobyka‌, thanks for your post.
When accessing SharePoint on Office 365, do you have the option to click on the Action Gear (Settings) > Site Settings > Site Collection Administrators, is your account also listed here? If not, go ahead and add your account.
Next, try accessing the Action Gear (Settings) > Site Contents > ArcGIS Maps > App Configuration to configure the app. Let us know if you have any issues!
Rudy
JustynaKobyka
Hi. My account wasn't listed to Site Collection Administrators. I used your instruction and add account to the Site Collection Administrators  and I confogurated ArcGIS Maps app but still when i try to add workflow I get alert :
ArcGIS credentials
Credentials are required to author ArcGIS maps and use the ArcGIS Maps Locate workflow.
RudyRuvalcaba1
Justyna Kobyka‌ Glad to hear you were able to add your account as a Site Collection Administrator.
The ArcGIS Maps Locate workflow will require ArcGIS Credentials. Depending on what url you connected to (ArcGIS Online/ArcGIS Enterprise), you'll need to set credentials for that organization.
Set the ArcGIS credentials
Were the organization credentials already configured and you're still seeing an issue? More info on the workflow can be found on the link below.
Regards,
Rudy
mazlianamohd_nordin
I try to configure arcgis maps for sharepoint in office 365 account, but it not success
I had follow the instruction from this documentation
Install ArcGIS Maps for SharePoint—ArcGIS Maps for SharePoint | ArcGIS
Please let me know if I've missed out the installation step.
Thank you,
Mazliana
RudyRuvalcaba1
Hi mazliana mohd nordin
If you're following the documentation, I assume you're a SharePoint site administrator already. I haven't run into this specific issue but I did find a similar error on the web. It may or may not be relevant. I would suggest opening a support case with Technical Support to further troubleshoot this issue. If you encounter any issue, send me a direct message.
Rudy
mazlianamohd_nordin
Hi Rudy Ruvalcaba,
Thank you its really helpful. We able to add ArcGIS Map for Sharepoint in site content.
Mazliana Mohd Nordin
