hscspl1
ssl certificate for arcgis
Discussion created by hscspl1 on Mar 27, 2019
Latest reply on Apr 16, 2019 by hscspl1
How does arcgis 10.6.1 pick up the ssl certificate? In other words, I how do I add the keystore location to arcgis server.
Documentation mentions the following :
In versions 10.5.1 and earlier, you imported CA-signed root certificates into the OS certificate store using the CA_ROOT_CERTIFICATE_DIR variable of the init_user_param.sh script. At 10.6, this step is no longer necessary.
IF CA_ROOT_CERTIFICATE_DIR is not needed, then how does arcgis pick up the certificate ?
I am trying to setup a 10.6.1 on Linux and it is picking up an invalid certificate. I am trying to troubleshoot and hence need the requested information.
Outcomes
