DEM Reconditioning Tool Error in ArcPro
1004
03-25-2019 09:20 PM
DanielNutsford
I am getting an error when running the DEM Reconditioning Tool in ArcPro 2.3 (see error message below). I am using a  raster layer as the input streams layer, as the tool also does not accept a feature class  input.
Has anyone experienced this issue, or have any ideas what might be causing it? I am using the latest toolbox download available for Pro (downloaded this week)
Cheers!
Dan
ChristineDartiguenave
I believe this issue has been fixed. Can you check with the latest version?
Christine Dartiguenave
Esri Water Resources Team
JacobHelfman1
New Contributor III
Christine Dartiguenave, I was able to successfully run it after I converted my input raster to Integer type. Was the DEM Reconditioning tool intended to be this way? If so, is there documentation covering the exact steps that should be followed (leading up to watershed delineation and beyond)?
