AnsweredAssumed Answered
Invoking SDE.ST_POLYFROMTEXT() results in "ORA-20004: Error generating shape from text:   (-3)."  What does the error code "-3" mean?
Question asked by mmercer on Mar 22, 2019
ArcSDE 10.4.1 on Oracle 11.2.0.4, Windows, 64-bit
I have a SQL statement that invokes the SDE function ST_POLYFROMTEXT.  I am using it to generate polygons from a given set of vertices.  I list the vertices in counterclockwise order and close the figure with the starting point.  When I run this statement in SQL (limiting to one row as a test):
select sde.st_polyfromtext('''polygon (('||bottomleftx||' '||bottomlefty||', '||bottomrightx||' '||bottomrighty||', '||toprightx||' '||toprighty||', '||topleftx||' '||toplefty||', '||bottomleftx||' '||bottomlefty||'))''', 4)
from psd.tblplatinfo where bottomleftx is not null and rownum = 1
I get this:
ERROR at line 1:
ORA-06512: at "SDE.ST_GEOMETRY_SHAPELIB_PKG", line 12
ORA-06512: at "SDE.ST_POLYFROMTEXT", line 59
I have googled on this, and found nothing useful; also I could not find anything that told me what the error code meant when I checked the ESRI support website.
If I take the function out, to capture what’s actually being generated:
select '''polygon (('||bottomleftx||' '||bottomlefty||', '||bottomrightx||' '||bottomrighty||', '||toprightx||' '||toprighty||', '||topleftx||' '||toplefty||', '||bottomleftx||' '||bottomlefty||'))'''
It yields:
SQL> /
'''POLYGON(('||BOTTOMLEFTX||''||BOTTOMLEFTY||','||BOTTOMRIGHTX||''||BOTTOMRIGHTY
'polygon ((1326474 724996, 1327270 726363, 1326563 726775, 1325767 725407, 1326474 724996))'
If I run that:
select sde.st_polyfromtext('polygon ((1326474 724996, 1327270 726363, 1326563 726775, 1325767 725407, 1326474 724996))', 4)
It works:
SQL> /
SDE.ST_POLYFROMTEXT('POLYGON((1326474724996,1327270726363,1326563726775,13257677
ST_POLYFROMTEXT(8, 5, 1325767, 724996, 1327270, 726775, NULL, NULL, NULL, NULL,
1294376.42, 4800.66956, 4, '2C00000001000000A4B9B6FFCF15AAE4D8F98711A595A802A0CF
FC03FC868702A3A59901E595A802C9FFFC03BC868702FAF59801')
Any idea what the error “-3” means?  What am I doing wrong?  It must be something simple, that I am just overlooking, but I can’t seem to find it.  Any ideas much appreciated.  Thanks!
Outcomes
