Do not repeat previous answer in a repeat group
431
03-21-2019 12:31 PM
ChantaleCarrier1
In a form for an inventory made with many groups and sub-groups, I have a repeat to enter many species. I must enter one specy per repeat and do not have the same specy entered twice for a parcel. Specy is entered from a select_one list presented as an auto-complete list.
I'm trying to do that if a specy is entered in the first repeat and that I try to enter it again in repeat 25,I could not enter it in 25 by being advertised by a color, by a text, or being unable to choose the same specy an other time during the repeats.
Example:
values entered
Repeat 1= Abies ×phanerolepis
Repeat 2= Abies balsamea
Repeat 3= Acer pensylvanicum
Repeat 25= try to enter again Abies ×phanerolepis and seeing in color, being advertising that it is already in the previous answer of Repeat 1 to 24, or something like this. Another way could be to remove from list the answers previously added.
Any idea how to do it?
JamesTedrick
Esri Esteemed Contributor
Hi Chantale,
This is possible by using a combination of the 'join' function to get a list of the values that have been entered and the regex() function to check for 2 or more entries of the current repeat.  See the attached example.  To break down the regex pattern:
regex(join(",",${prov_terr}), concat("(.*", ${prov_terr}, ",?.*){2,}"))
  • join(",",${prov_terr}) - creates a list of the selected items in the repeat
  • concat() - joins the sub-parts of the regex term together, using the current field value.  If British Columbia had been selected, it would become (.*BC,?.*){2,} , which I will use below
  • (.*BC,?.*){2,}
    • ( ) - everything inside the parenthesis is one thing to match
    • .* - match anything, including no characters
    • BC - match the letters BC
    • ,? - an optional match for a comma
    • {2,} - have at least 2 matches
Note that there is currently an issue with Survey123 raising constraints when the first value in a repeat sequence is valid.  As a substitute, you can have a warning note appear to alert the user the value has already been entered.
ChantaleCarrier1
Thanks James,
If the values (species) are coming from an external database by a pulldata function, how should I add it in the function?
Ex.: A .csv that include species only
Thanks for your help!
JamesTedrick
The method of where the species comes from shouldn't matter, just the check for identical values in the answers.
