is it possible to have the photos captured with a Survey 123 form using send to a network share ?
Hi Jevita,
Yes, this should be possible if you can get the attachments via the connector, then you should be able to send them to other file sharing services, and if Integromat supports your type of network share and it can be added, then yes it should work.
Note the Integromat connector is still in beta and we are working on updates to it to support attachments, so please follow the EAC site for updates and provide feedback over there: https://earlyadopter.esri.com/project/home.html?cap=e69ef91f45744b98882c651f7b518eb7
Phil.
