Mobile Map Package
1000
03-21-2019 04:01 AM
DavidPeña1
Is there any possibility to close an MMPK file with .NET SDK? I mean, I open in my program the MMPK file in order to retrieve some data with MobileMapPackage.OpenAsync(path) method.
The file stays locked while the program is running because I am not able to found any method to close tha file and release it.
Is there any  method to do that?
Thanks in advance
Tags (1)
MichaelBranscomb
Esri Frequent Contributor
Currently there isn't a high level way to close a Mobile Map Paclage - but we have an issue in our backlog to support this in a future release. I have added your request to that issue.
Cheers
Mike
JoeHershman
MVP Regular Contributor
I use a brute force approach loop through the layers, get the geodatabase and call Close on the Geodatabase objects.
Not sure what your issue is with locking, I have found even after calling close there still seems to be some lock on the files
-Joe
MaraStoica4
Take a look at how I've released the references to the mmpk to be able to delete it in the Offline Mapbook example app:
https://github.com/Esri/mapbook-wpf/blob/4d58ce6e7bb7b6c0308cdc59ea445c6e8e931503/OfflineMapBook/Off...
