AnsweredAssumed Answered
Issue with adding raster function template to SD draft
Question asked by vikshut on Mar 21, 2019
Hi. I am working on automating an image service publishing workflow in arcmap 10.6.
From the python window, I executed the following in sequence:
CreateGISServerConnectionFile
CreateMosaicDataset_management
AddRastersToMosaicDataset_management
CreateImageSDDraft
However, when I executed the following code, the raster function template did not get added to the SD draft. There is no error message either. Hoping for a resolution here!
# Add raster function template to sd draft
import xml.dom.minidom as DOM
functemp = "G:\\RGBComposite.rft.xml,None"
xml = "F:\\Connection\\test_Orthomosaic.sddraft"
dom = DOM.parse(xml)
properties = dom.getElementsByTagName('PropertySetProperty')
for prop in properties:
    keynodes = prop.getElementsByTagName("Key")
    for keynode in keynodes:
            if keynode.firstChild.nodeValue == "rasterFunctions":
                valnodes = prop.getElementsByTagName("Value")
         for valnode in valnodes:
                 if valnode.firstChild == None:
                     valnode.appendChild(dom.createTextNode(functemp))
                 else:
                     valnode.firstChild.replaceWholeText(functemp)
Outcomes
