MapView rotation with Graphic containing TextSymbol
284
03-21-2019 02:02 AM
DanielLechner1
Equally to the PictureMarkerSymbol (as stated in the other question PictureMarkerSymbol rotation 4.9 vs. 4.10 ) also the TextSymbol is staying screen-aligned from 4.10 on.
4.9
4.10
As you can see in the given samples its not always nice to have it like that.
Is this same as for the PictureMarkerSymbols the wanted behaviour?
If yes, it would be nice to have a property on the symbols to give developers the possibility to force the behaviour they want.
Is there any possibilty to change the rotation with 4.10/4.11 other than removing and adding again the whole graphic with the rotated symbol?
RobertScheitlin__GISP
Daniel,
   I just tested this in 4.11 and the offset is still ignored. Have you filed a bug with esri tech support on this?
