Arctics pro slow in local shapefile
307
03-12-2019 12:16 PM
KeWang1
My Arcgis pro is 2.3, the newest version, but it is too much slow. For example, chnging a symbol for a country border polygon (which I download from nature earth) will take 10+min or totally crash down. The polygon is local file, the same projection.
the weird thing is , when I use the "world countries" from Arcgis online in Arcgis pro, changing symbols seems normal again. Can anyone tell me what is the issue? Projection ? Or the Arctic pro does not recognize my local file? Thanks.
by Anonymous User
Not applicable
Hi Ke,
If you are working with a shapefile (especially a large shapefile with many features), can you try this?
  • If necessary, remove the shapefile from the map
  • Find the shapefile in the Contents pane
  • Right-click on it and select Properties
  • Click on Indexes in the left pane and expand Spatial Index in the right pane
  • Is there a spatial index associated with the shapefile?
    • If not, click Create
    • If yes, Click Delete, then Create
  • Once the Spatial Index is created, click OK to close the Shapefile properties
  • Re-add the shapefile to the map and try changing the symbology. Any improvement in performance?
I'm hoping so!
-Lauren
KeWang1
Lauren:
Thanks a lot! I am try later
Ke
