Custom parse Python string
1439
11
03-12-2019 02:47 PM
JeremyMcCollum1
I have an attribute field that has a description that I only want to display a specific string or text.  I'm not sure if using a rsearch or rfind or another method for displaying what I want is best? For example, the text field:
 VILLAGES OF WOODLAND SPRINGS BLOCK 44 LOT 4
FIVE OAKS CROSSING ADDN BLOCK 1 LOT 6 PER PLAT D214124070
SUMMER CREEK SOUTH ADDITION BLOCK 8 LOT 3
I am only wanting to pull out the Block and block number and Lot and Lot number
thanks for any advice
DanPatterson_Retired
Jeremy you might want to mark mine correct.
Now for the ones with the spaces, you will have to modify indx0 for those cases
for example...
idx0 = row.index('BL OCK')
JoshuaBixby
MVP Esteemed Contributor
>>> import re
... strings = [
...     "VILLAGES OF WOODLAND SPRINGS BLOCK 44 LOT 4",
...     "FIVE OAKS CROSSING ADDN BLOCK 1 LOT 6 PER PLAT D214124070",
...     "SUMMER CREEK SOUTH ADDITION BLOCK 8 LOT 3"
>>> for s in strings:
...     print(re.findall('(BLOCK|LOT) (\S*) ?',s))
[('BLOCK', '44'), ('LOT', '4')]
[('BLOCK', '1'), ('LOT', '6')]
[('BLOCK', '8'), ('LOT', '3')]
A fake field and a function to try with the field calculator, python parser,
code block is below.
expression line
do_stuff(!YourFieldNameHere!)
lines 14-16 simulate a fake column 'a'
hopefully you get the drift. I wrote it as overtly as possible
a = [ 'VILLAGES OF WOODLAND SPRINGS BLOCK 44 LOT 4',
'FIVE OAKS CROSSING ADDN BLOCK 1 LOT 6 PER PLAT D214124070',
'SUMMER CREEK SOUTH ADDITION BLOCK 8 LOT 3']
def do_stuff(a_val):
    """call using do_stuff(!Your_fld!)"""
    row = a_val.split(" ")
    idx0 = row.index('BLOCK')
    idx1 = row.index('LOT')
    out = " ".join(row[idx1:idx1+2] + row[idx0:idx0+2])
    return out
for a_val in a:
    returned = do_stuff(a_val)
    print(returned)
LOT 4 BLOCK 44
LOT 6 BLOCK 1
LOT 3 BLOCK 8
JeremyMcCollum1
My example that I used actually has lots and lots of blocks and lots with numbers, what could I use to grab them all?
show an example.
Is the stuff in a table (see the field calculator example I posted) or what format are they in?
JeremyMcCollum1
add a new text field and try the field calculator code block and expression I posted.  python parser code block as above and the expression would be
do_stuff(!legaldesc!)
JeremyMcCollum1
Can I see how you put this in?  I can't get mine to work.  I am also doing this in ArgGIS Pro, not sure if that will make a difference
JeremyMcCollum1
legaldesc is the attribute field that I am looking to do this on
for the visual types...
I swapped the code block up so block appears before lot (my bad in the original)
