Roads and Highways/WMX JIT Debugging Message
681
03-07-2019 12:11 PM
anayoung
New Contributor III
When extending a route and retiring existing route underneath newly extended route, the following attached message appeared.
More specifically, extended two new routes in opposite directions then tried to retire route(s) underneath one at a time. System didn't like it. Applied updates - no difference.
Able to avoid message by extending only one route at a time then retiring one route, could not have two newly extended routes.
Ana
NathanEasley
Hi Ana,
Can you open a case with Esri Technical Support for this issue?  For an error like the one you encountered, we'd like to get it fixed within the software.
Nathan
anayoung
New Contributor III
Thank you, Nathan. We will do that.
