Adding Media to PopupTemplate
1182
5
02-27-2019 06:29 AM
MohamadMousheimish1
I'm currently using the PopupTemplate class from esri. As I noticed we can load an image and view it in the PopupTemplate. My question is can we load a video of type mp4?? Or a voice of type mp3 to the PopupTemplate??
Or is the media type restriced only to mediaInfos of type image ??
RobertScheitlin__GISP
Mohammed,
  I don't think those are supported media info types but you can add a video to a popup as seen here:
https://community.esri.com/thread/121245
Mohammed,
MohamadMousheimish1
Thank you for your answer and for your reference, but I'm sorry to let you down. The provided link didn't have what I wanted. Loading the video into my PopupTemplate didn't work out. I think they're using an old API version since I'm using latest (4.10)
Mohamad,
  Converting that example to 4.10 is not very hard. Did you try?
MohamadMousheimish1
Robert, after implementing some instructions used in the link you sent yesterday. Things worked fine.
Thank you for your response. Appreciate it.
BirajaNayak
Here is the sample code in 4.10 in case anyone wanted it in future:
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
<title>PopupTemplate with video - 4.10</title>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<link rel="stylesheet" href="https://js.arcgis.com/4.10/esri/css/main.css">
<script src="https://js.arcgis.com/4.10/"></script>
<script>
require([
"esri/Map",
"esri/layers/FeatureLayer",
"esri/views/MapView"
], function(
Map,
FeatureLayer,
MapView
// Create the map
var map = new Map({
basemap: "gray"
// Create the MapView
var view = new MapView({
container: "viewDiv",
map: map,
center: [-73.950, 40.702],
zoom: 11
var template = { // autocasts as new PopupTemplate()
title: "Marriage in NY, Zip Code: {ZIP}",
content: getContent()
function getContent(){
var Content = "<b>City Name: </b>" + "{areaname}" + "<br> <b>Population: </b>" + "{pop2000}" + "<br>";
var Hyperlink = '<video width="250" height="250" controls><source src=http://techslides.com/demos/sample-videos/small.mp4 type=video/mp4></video> ';
return Content + Hyperlink;
// Reference the popupTemplate instance in the
// popupTemplate property of FeatureLayer
var featureLayer = new FeatureLayer({
url: "http://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer/0",
outFields: ["*"],
popupTemplate: template
map.add(featureLayer);
</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
</html>
