AnsweredAssumed Answered
How do I skip attributes that are null or blank?
Question asked by NEOMAPPER on Feb 26, 2019
Latest reply on Feb 26, 2019 by PYadav-esristaff
Is there a way to check if a field is blank or null and if it's not continue the script? I can't quite get the function to work unless I'm missing something. Thanks
 if row[0] != "": # if field is not blank or null then...
import sys
import os
import arcpy
sdeconnection = "Database Connections/SDE.sde"
fc = 'Database Connections/SDE.sde/NEO.SDE.Inspections/NEO.SDE.ACInspectionSites2019'
fields = ["INSPECTEDBY", "INSPECTIONSTATUS"]
try:
    edit = arcpy.da.Editor(sdeconnection)
    print "edit created"
    edit.startEditing()
    print "edit started"
    edit.startOperation()
    print "operation started"
    # Perform edits
    with arcpy.da.UpdateCursor(fc, fields) as cursor:
        # For each row, evaluate the WELL_YIELD value (index position
        # of 0), and update WELL_CLASS (index position of 1)
        for row in cursor:
                row[1] = "Completed Inspection"
                # Update the cursor with the updated list
                cursor.updateRow(row)
    edit.stopOperation()
    print "operation stopped"
    edit.stopEditing(True)  ## Stop the edit session with True to save the changes
    print "edit stopped"
except Exception as err:
    print err
    if 'edit' in locals():
        if edit.isEditing:
            print "operation stopped in except"
            edit.stopEditing(False)  ## Stop the edit session with False to abandon the changes
            print "edit stopped in except"
finally:
    # Cleanup
    arcpy.ClearWorkspaceCache_management()
Outcomes
