Changing Staging/SharingProcesses folder for publishing web layer from Pro
1126
02-25-2019 11:07 AM
JosephRhodes1
I have a large set of tiles that I need to publish to ArcGIS Online. Unfortunately, my default hard drive is not large enough to accommodate the files that are created during the staging process and stored in AppData\Local\ESRI\ArcGISPro\Staging\SharingProcesses\0004. The tiles are in a mosaic dataset, which I'm sharing by right-clicking the mosaic in the TOC --> share as web layer --> tile layer.
My question is: Is it possible to change that path to one to an external drive with sufficient storage?
Thanks!
ChrisLandvogt
Hi Joseph,
I know you've asked this question some time ago, but I thought I'd add the resolution in case others came across this issue, too.
You are able to change the Staging Folder location in ArcGIS Pro -> Options -> 'Share and Download'. The first setting 'staging' allows you to manually specify the staging folder.
Regards,
Chris
Esri Australia
