WAB error on IE11
1356
6
02-25-2019 09:50 AM
rajujee
New Contributor III
Hello experts,
My WAB application is not working with latest WAB Developer Edition (v2.11) in IE11 only.  It shows continuous loading size in the browser.
I get error on init.js
Error: abort("Assertion failed: no binaryen method succeeded."). Build with -s ASSERTIONS=1 for more info.
I am using a custom widget that requires me to use WAB Developer Edition.
PLEASE HELP!
RobertScheitlin__GISP
rajujee
New Contributor III
Thanks Rob for quick response. I am using latest version v2.11. It is totally different error
Raju,
  Is The application running in compatibility mode in IE?
rajujee
New Contributor III
Thanks Rob for always being helpful. Application is not running on compatibility mode.
Do you suggest to implement following code as a work around ?
IE11 support broken due to emscripten issue · Issue #96 · medialize/sass.js · GitHub
if (!self.crypto) {
self.crypto = {
getRandomValues: function(array) {
for (var i = 0, l = array.length; i < l; i++) {
array = Math.floor(Math.random() * 256
return array;
No. I am not having an issue with WAB 2.11 in IE 11... So I am not sure what you issue is if your app is running in Edge mode and not compatability mode.
LeonAus
New Contributor III
I am also getting this problem. Same version of IE and WAB. Was there any solution?
Thanks.
