Relationship for attachments - related items in table
848
6
02-24-2019 03:36 AM
Nicole_Ueberschär
I have a point feature class with attachments. While I can see the attached items in the identify tool I cannot directly access the items through the related tables which does not make sense to me. Is that the desired behaviour? When I want to remove an attached item it is not very comfortable to look for the right file in the whole table. Instead I would expect to get the attached items through the related table function and then would easily be able to remove the desired file. Did I miss something?
Nicole_Ueberschär
Haha, yes, either or
Well, just when I was trying to summarize for support what does not work I thought "maybe I have to relate my tables again to make that work" et voilà: It works. I would still think that having a relationship class should do the job but it doesn't...
DanPatterson_Retired
Attachments toolset... is it a license issue?
The tools in the Attachments toolset require an ArcGIS Desktop Standard or Desktop Advanced license.
Nicole_Ueberschär
No, can't be. I am running an Advanced License.
so you aren't using the Attachments tools then?
Nicole_Ueberschär
Well, I used the create Attachments option in the context menu of the feature class. That creates the attachment table and the attachment relationship class. The attachments themselves are created and attached through a python script.
When I do the same (step by step) through the toolbox I end up with the same result.    I can see the attachments with the identify tool but I cannot access them through the related table in the attribute table. That can't be wanted...
people are quite attached to their attachments
https://community.esri.com/search.jspa?q=attachments&place=%2Fplaces%2F478947&depth=ALL
but none cover your case, so it is either so obvious how to do it, or it can't be done, or it isn't a suggestion
Nicole_Ueberschär
