I have started to notice that when I open surveys in my inbox the photos that were taken originally have started to disappear and since for me this is a required field I then cannot make changes to the survey as it cannot be resubmitted. This is only reflected in the Survey123 App, on my ArcGIS Online WebMap the pictures are there and can be opened. Is this a glitch with a recent update or has there been a change as to how the photos should be taken?
Hi Kerr,
Editing of attachments (photos) are not supported via the Inbox. This means if you open an existing survey via the Inbox, and have an image question in the parent layer, you will not be able to add a new photo. You can however put your image questions inside a repeat, and via that method you can add new photos to an existing parent record, by adding new repeat records with attachments.
We have an open enhancement request to support editing attachments via the Inbox, currently in backlog, I have updated your request for this feature in the issue.
Phil.
