LocationDisplay not compatible with Android Location
465
02-21-2019 02:40 PM
by Anonymous User
Not applicable
Am noticing that with the 100.4 LocationDisplay there is no longer a way to retrieve the number of satellites without setting up a separate Android location listener.
10.2.9 returns an Android Location
Location location= mMapView.getLocationDisplayManager().getLocation();
100.4 returns and ESRI location
com.esri.arcgisruntime.location.LocationDataSource.Location wgsLocation = mMapView.getLocationDisplay().getLocation();
The problem is that I want to get the number of satellites which the ESRI location method does not appear to support...The code below is run on a timer to update the number of satellites from the getLocation code mentioned above.
For example in 10.2.9..
Bundle sats = location.getExtras();
int x = sats.getInt("satellites");
Yes I could have an Android location listener and and ESRI location listener but this seems awfully redundant...
