rupert12
dsmapbook compatibility
Discussion created by rupert12 on Feb 24, 2011
Latest reply on Mar 30, 2011 by HeatherW
Does anyone have dsmapbook working on a windows 7, 64-bit machine, running ArcGIS 9.3.1?
I can't get it to install correctly.
When I install dsmapbook on my windows7 64bit computer and ArcGIS 9.3.1 SP2, the install does not work correctly. There is no mapbook tab added to the TOC and when I hit the Create Map Book tool on the map series toolbar, I get an error message that says "Map Bood code not installed properly!! Make sure you can access the regsvr32 command and rerun the _Install.bat batch file!!
All messages given during install suggest a successful install was done and that the registry was updated.
Any ideas.... anyone?
Outcomes
