Cannot call this method in this context
1529
02-21-2019 05:52 AM
AgencyDeveloper
I keep getting  java.util.concurrent.ExecutionException: com.esri.arcgisruntime.ArcGISRuntimeException: Cannot call this method in this context for the tableQueryResult.get(); Any clue why?
Thanks in Advance.
    private void queryFeaturesFromTable() {
        ServiceFeatureTable table = new ServiceFeatureTable(
                "https://services3.arcgis.com/GVgbJbqm8hXASVYi/arcgis/rest/services/Trails/FeatureServer/0");
        table.loadAsync();
        table.addDoneLoadingListener(() -> {
            QueryParameters query = new QueryParameters();
            query.setWhereClause("1=1");
            query.setReturnGeometry(true);
            ListenableFuture<FeatureQueryResult> tableQueryResult = table.queryFeaturesAsync(query);
            tableQueryResult.addDoneListener(() -> {
                try {
                    List<Graphic> graphics = new ArrayList<>();
                    FeatureQueryResult result = tableQueryResult.get();
                    result.forEach(feature -> {
                        graphics.add(new Graphic(feature.getGeometry()));
                } catch (ExecutionException | InterruptedException e) {
                    System.out.println("Error querying Service Table:  " + e);
Tags (1)
by Anonymous User
Not applicable
Can you share more of your code? It works fine for me as follows:
import com.esri.arcgisruntime.concurrent.ListenableFuture;
import com.esri.arcgisruntime.data.FeatureQueryResult;
import com.esri.arcgisruntime.data.QueryParameters;
import com.esri.arcgisruntime.data.ServiceFeatureTable;
import com.esri.arcgisruntime.mapping.ArcGISMap;
import com.esri.arcgisruntime.mapping.Basemap;
import com.esri.arcgisruntime.mapping.view.Graphic;
import com.esri.arcgisruntime.mapping.view.MapView;
import java.util.ArrayList;
import java.util.List;
import java.util.concurrent.ExecutionException;
import javafx.application.Application;
import javafx.geometry.Insets;
import javafx.geometry.Pos;
import javafx.scene.Scene;
import javafx.scene.control.Button;
import javafx.scene.layout.StackPane;
import javafx.stage.Stage;
public class GetQueryResultsRuntime extends Application {
  private MapView mapView;
  @Override
  public void start(Stage stage) throws Exception {
    StackPane stackPane = new StackPane();
    Scene scene = new Scene(stackPane);
    stage.setTitle("Display Map Sample");
    stage.setWidth(800);
    stage.setHeight(700);
    stage.setScene(scene);
    stage.show();
    ArcGISMap map = new ArcGISMap(Basemap.createImagery());
    mapView = new MapView();
    mapView.setMap(map);
    stackPane.getChildren().addAll(mapView);
    Button button = new Button("Query");
    button.setOnAction(event -> {
      queryFeaturesFromTable();
    StackPane.setAlignment(button, Pos.BOTTOM_RIGHT);
    StackPane.setMargin(button, new Insets(15));
    stackPane.getChildren().add(button);
  @Override
  public void stop() {
    if (mapView != null) {
      mapView.dispose();
    table.loadAsync();
        try {
          System.out.printf("%d graphics\n", graphics.size());
  public static void main(String[] args) {
    Application.launch(args);
AgencyDeveloper
Thank you Gary for your response. I copy pasted your code in my IDE and tried running it. I ran the code and the application window showed up. On clicking the query button, I still get the same error
Error querying Service Table:  java.util.concurrent.ExecutionException: com.esri.arcgisruntime.ArcGISRuntimeException: Cannot call this method in this context
My console output is :
Initializing...
Java version : 1.8.0_191 (Oracle Corporation) x86_64
I am using Eclipse with Java 8 and downloaded the java sdk and have the following dependencies added
arcgis-runtime-sdk-java-100.4.0/libs/arcgis-java-api-javadoc.jar
arcgis-runtime-sdk-java-100.4.0/libs/arcgis-java-api.jar
arcgis-runtime-sdk-java-100.4.0/libs/commons-codec-1.11.jar
arcgis-runtime-sdk-java-100.4.0/libs/commons-logging-1.2.jar
arcgis-runtime-sdk-java-100.4.0/libs/gson-2.8.5.jar
Is something wrong with my config?
