AnsweredAssumed Answered
Rotate Feature by degree in Pro
Question asked by Mtclimber03 on Feb 20, 2019
Latest reply on Feb 20, 2019 by rleclair-esristaff
Does anyone know how to use the rotate editing tool in ArcGIS Pro to rotate a feature by an exact degree? This can be done in ArcMap and I can't figure out how to do this in pro. In ArcMap to achieve this you do the following.
  1. Click the Rotate tool Rotate Tool on the Editor toolbar.
  2. Click anywhere on the map and drag the pointer to rotate the feature to the desired orientation. To specify the exact degree of rotation, press the A key, and type the number of degrees. The angle is applied relative to the current orientation. A positive number rotates the feature to the right; a negative number rotates it to the left. Angular units are determined by the angular or direction units setting on the Units tab of the Editing Options dialog box.
I cannot find this functionality in ArcGIS Pro.
Outcomes
