Cant open ArcMap, Please Help
1484
02-20-2019 07:03 AM
AnnaBeger
Hi! My ArcMap (10.6 for Windows) won't open a Window anymore.. it says initialising and looks like it would start normally, but then nothing happens. The licence is still valid until April, ArcCatalog opens normally. It also shows up in the Taskmanager in Backround processes. Can anybody help me with this?
AdrianWelsh
MVP Honored Contributor
Anna,
Maybe you could try resetting your ArcGIS Profile?
https://community.esri.com/docs/DOC-2121-resetting-your-arcgis-application-profile
And if that doesn't work, it may be worth doing a Repair Install on your ArcMap desktop
shan_sarkar
Occasional Contributor III
Anna,
I assume you have already verified the ArcGIS Desktop 10.6.x system requirements—System Requirements | ArcGIS Desktop prior installing the software., which includes all the prerequisites for ArcGIS Desktop.
Could give this a shot Can You Run It?
I hope this helps!
~Shan
~Shan
AdrianWelsh
Anna,
Are you still having issues with opening ArcMap?
