AnsweredAssumed Answered
global name is undefined
Question asked by ardiarmanto on Feb 19, 2019
Latest reply on Feb 19, 2019 by lpinner
I'm trying to execute zonal statistics but I'm experiencing an error like this:
C:\Python27\ArcGIS10.5\python.exe "D:/WWF - Sustainable Hydropower/FRA/Code/f1_zonal_stats.py"
Running against: 2.7.12 (v2.7.12:d33e0cf91556, Jun 27 2016, 15:19:22) [MSC v.1500 32 bit (Intel)]
Running python 32 bit
> v0.3 (dev_gg)
Starting at 20190219155051
File "D:/WWF - Sustainable Hydropower/FRA/Code/f1_zonal_stats.py", line 179, in <module>
zonal_statistics(*argv)
File "D:/WWF - Sustainable Hydropower/FRA/Code/f1_zonal_stats.py", line 48, in zonal_statistics
set_environment(workspace, fd.masked_layer)
NameError: global name 'fd' is not defined
This is my code:
import csv
import datetime
import os
import sys
import time
from collections import defaultdict
import arcpy
from arcpy.sa import *
def zonal_statistics(*argv):
    Calculates the Zonal statistics usinf a raster grid ans a zone grid/vector and extracts the results to a feature class
    :param values_path: Path to the values grid
    :param zones_path: Path to the zone grid
    :param 'out_feature_class': Feature class as target to append data
    :param type of statistics. Can be 'sum', 'avg', 'min', or 'max'
    :return: adds statistics values to 'out_feature_class'
    print ("> v0.3 (dev_gg)")
    # Jan 6, 2017:
    # Added newly created RDD_B1_URB and NLI_B1_URB
    # Limited Nightlights to Urban areas
    # Limited Roads to outside urban areas (correlation with urban)
    # Changed ABS to CON (Consumption)
    # Calculates river reach zonal stats from a set of input layers as defined in 'csv_name'
    """ The output layer is defined in the CSV file"""
    # Its here: C:\temp\FFR_Results\1_ZonalResults\ZonalResults.gdb\streams_results_ffr
    start = time.clock()
    __location__ = os.path.realpath(os.path.join(os.getcwd(), os.path.dirname(__file__)))
    TIMESTAMP = int(datetime.datetime.fromtimestamp(time.time()).strftime('%Y%m%d%H%M%S'))
    print "Starting at %s" % (str(TIMESTAMP))
    workspaceFolder = os.path.join(r"C:\temp\FFR_Results\1_ZonalResults", 'Temp')
    make_sure_path_exists(workspaceFolder)
    workspace = createWorkspace(workspaceFolder, TIMESTAMP)
    # Set environment
    # csv_name = r"E:\Dropbox\Projects\FFR\Code\ZonalGridTransfer\FFR_India_input.csv"
    csv_name = r"E:\Dropbox\Projects\FFR\Code\ZonalGridTransfer\FFR_input.csv"
Outcomes
